From what I understand, the 7th gen Civic still uses a D series engine, so a CX/VX trans should bolt up to the engine, I’d build a high compression D16 and the tallest transmission I could run behind it... I’d go for lean burn but you may decide to skip on the more expensive O2 sensors
My current Ecotec project...
![](http://ecomodder.com/forum/fe-graphs/sig10025a.png)
My last Ecotec project...
