Old 08-22-2018, 02:28 AM   #16 (permalink)
Xist
The cheapest gas station in-town is at a car wash and each pump accepts cash. I took a picture of it because I had not seen it before. There is one machine to give change. When I do not have a fuel discount or access to a Costco I go to an AM\PM, but I have always seen one cash machine with each set of pumps, and you get change from inside.
However, I do not remember the last time that I was able to use a cash machine. They always seem to have signs saying to pay inside.
I think that the only way to keep play balls from eventually absorbing gas through a crack or hole would be to use solid balls.
That would take away from those thirty-seven pounds saved.
How much less would a 6-gallon tank weigh?
