Old 08-31-2008, 12:13 PM   #15 (permalink)
wjdennis
Ryland, so far I'm happy with the ThunderSky cells. There are the older LCP cells, but I think you'd probably want to go with the newer LFP cells now. The only issue I've encountered so far is that the cells get too hot when I pull more than .33C out of them, so I'm going to have to install an active cooling system. I'd suggest installing three times the Ah that you think you'll need in average amps. For example, if you car will be pulling 100A in average driving, then install 300Ah worth of cells.
Bill
