Old 08-22-2018, 09:12 PM   #24 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Not for an HCH, but it's essentially the same as the Insight. I marked each step in the wiring a different color. Green is motor to rectifier, blue is rectifier to PSU, red is PSU to the front of the car to the 12v battery.
There's basically just a long 8 gauge wire from the 12v battery to the back of the car already, makes this all very easy.
Is it really just that simple?
Does the HCH/Insight have an alternator that needs to be disconnected/deleted? This then solves the issue of needing to be between 1500 & 3800 RPMs for charging the battery?
I say "simple" although I've never really done any wiring stuff on cars before; however I enjoy learning new stuff and a few youtube tutorials should get me going along with your diagram once I get an HCH...or an Insight...I'm still debating...
Probably around 33%. I'd say 70mpg is a realistic but non-trivial goal in an HCH1, while 90mpg is a realistic but non-trivial goal in an Insight (for a full tank). You can reach either with a completely stock car and consistently careful driving.
Of course, points in the HCH1's favor are that MPG is not a very good metric. 70mpg is 3.3L/100km, while 90mpg is 2.6L/100km. In an absolute sense, it's the same amount of fuel saved as going from 25mpg (9.4L/100km) to 27mpg (8.7L/100km), because both cars already use so little.
Wowsers. I'd say 50-55 MPG would be a "realistic but non-trivial" goal for my car, although by extreme hypermiling I can get 60-70. That'd be a 33% in and of itself over my current car with the HCH and 75% better with the Insight. Would that be with/without battery and ecomods?
Me want...but what about impracticality!
If I can find a good Insight next spring and I don't see a super tempting HCH...I just might go with the Insight.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
