Losses drop or losses rises to 50?
If it go from 10 degree to 40 degree the losses must rise, and the energy production drops.
Fixed tracking is more of a sales pitch.
As long as you are kind of pointed st the sun you only give up 1% when pointed 10 degrees off true perpendicular.
As the sun is not pointed at the panels your losses drop to 50% by the time you are off by 40 degrees or so if I remember correctly.
There is a mathematical equation to figure it out, I used to know it.
