Old 08-25-2018, 05:02 PM   #12 (permalink)
JLC
I was incorrect in my OP it won't run off 24v as it is run directly off the H.V. battery.
I would need a controller to run the compressor motor, I had thought about utilizing the inverter/converter assy out of the Prius as well, however I believe I would need to basically use all the wiring out of the Prius to pull that off due to H.V. ecu, compressor ecu, ...etc.
However what about an option like this?
https://www.alibaba.com/product-deta...57685ee1sGGyEG
Run from it's own 12v battery with Isolator fed from 200a alternator?
