Originally Posted by Clev
Would the fuel system keep pumping in fuel if the car is moving in gear with the ignition killed?
You shouldn't kill the engine with it in gear. Is what I would think.
Originally Posted by MetroMPG
I should do a writeup of my ignition coil kill switch method. It would be interesting to compare the two methods to see if there's any difference in the way the car stops/restarts.
Do it!!
People need choices. I did mine like that but didn't like the idea of pumping in fuel that didn't burn. But mine is TBI so it is a little different than some. Takes more time for fuel to reach cylinders than MPFI does.
