Originally Posted by Ecky
Even better than cylinder deactivation is taller gearing.
Dropping the RPM with a taller gearing while cruising sounds like a cost-effective approach. Not sure if the final results would be so similar to what the OP might be expecting, but still seems to be a safe bet.
