Old 08-28-2018, 04:07 PM   #81 (permalink)
Piotrsko
Ok so best case you are planning on perhaps 1500 watts max out of this if you can excite the motor properly and not melt the field windings.
I'm a bit sketchy on regen in A/C synchronous motor theory
If you go 3 phase, you can use a RC toy electric motor controller from slamazon or fleabay real cheap. If you use a brushed universal motor, those are easy to control
If you are doing recyclable parts, see if you can score a discarded battery lawnmower. They are brushed dc and about the correct size
