Old 08-28-2018, 06:02 PM   #10 (permalink)
ProDigit
Dropping the RPM with a taller gearing while cruising sounds like a cost-effective approach. Not sure if the final results would be so similar to what the OP might be expecting, but still seems to be a safe bet.
Roughly speaking for every 12% in gearing increase, you'll get a 10% of MPG increase.
It's not linear, meaning you'll get better MPGs at lower speeds, and MPGs at highway speeds will be closer to identical; to worse (when the engine load is too high, and the engine is pinging or knocking).
