Originally Posted by MetroMPG
Don't pass up a good pre-96 if one presents itself. You can use an MPGuino for fuel economy instrumentation if it's not ScanGauge compatible.
I second that, the scangauge will also not be able to calculate for leanburn in the vtec-e system and the MPGuino doesnt have a problem with it.
I'm waiting for my MPGuino to come in the mail because i'm converting my HX to OBD1
As far as inspecting goes make sure to do @ least a compression test and maybe a leakdown if you can. Avoid the CVT variety and make sure the 5 speed sounds ok, no grinds, no bearing noises. Oh, make sure you dont have any o2 related CELS because the sensor is $$$$ to replace.
If the HX doesnt have the original wheels (11.5 lbs apeice) you should haggle to price down a bit.
happy hunting
and 60+ mpg will be waiting
