Originally Posted by JSH
Alignment issues are due to part issues. No one is manually adjusting panels on the assembly line. Instead the operator places a gauge block between two panels that sets the correct gap and then tightens the bolts. That only works if the panels are correct. If they parts are not correct then the gap will be off and the errors will stack on top of each other from panel to panel. Yes, the panels MIGHT be able to be fixed by having a technician loosen everything up and try to "best fit" the gaps but that is a very slow and expensive rework.
Alignment issues can be due to part manufacturing issues, but they can also be due to assembly issues. Everything I've seen suggests the problems with panel alignment on the 3 are in assembly, not panel/parts production. Until we start building cars where the panels align perfectly regardless of how they're assembled, there can be issues with panel gap/etc during assembly.
