Old 09-05-2018, 11:56 AM   #153 (permalink)
samwichse
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
https://wyoming.craigslist.org/cto/6688897278.html
You NEED this.
This is a super rare 1991 Suzuki Swift GTI with the 1.3L DOHC. These were not production cars in the states.
The car comes with the white wheels picture
35mpg
The Suzuki Cultus is a supermini car produced by the Japanese manufacturer Suzuki from 1983 to 2003, and it is now a rebadged Suzuki Celerio in Pakistan since 2017. It was first presented at the 25th Tokyo Motor Show, formally introduced to Japan in 1983 and ultimately sold in seven countries across three generations and marketed worldwide as the Suzuki Swift. An alliance formed in 1981 between GM and Suzuki (and Isuzu) allowed GM to market the Cultus as a captive import internationally under more than a dozen nameplates including the Geo Metro, Chevrolet Sprint, Pontiac Firefly and Holden Barina.[1] It was also known as the M-car within GM.
The higher powered Swift GTi had an improved G13B engine which featured hollow camshafts, stronger web casting on the engine block, a better flowing intake manifold (the prior generation intake manifold had its shape compromised to fit into the engine bay), and its ECU now had electronic control over ignition timing. It now put out 101 PS (74 kW; 100 hp) of power. The GTi also featured all wheel disc brakes. Japanese GTi's have a much higher compression ratio (11.5:1) and accordingly more power at 115 PS (85 kW; 113 hp).
Asking $3000 OBO
The Following User Says Thank You to samwichse For This Useful Post:
MetroMPG (09-05-2018)
