Old 09-05-2018, 01:15 PM   #133 (permalink)
Daox
I got my alternator delete working this past weekend. I had some issues getting the alternator to turn off and stay off. So, I ended up making a simple little circuit with a dc-dc converter to trick the voltage regulator on the alternator to thinking the battery's voltage is higher than it really is. That did the job quite nicely. Here is a schematic of the circuit.
It all taps in via a fuse that goes to the sense wire on the alternator. So, I 3d printed a fuse body, and cut some metal tabs to put in it. A bit of super glue and solder and it works great for a plug in modification. There is only one other connection necessary and that is a wire to ground.
3d printed fuse tap.
The whole circuit.
It fits nicely in the fuse box under the hood. Yeah, this means I have to open the hood to turn the alternator on if necessary. That will change.
The Following 4 Users Say Thank You to Daox For This Useful Post:
California98Civic (09-07-2018), HHOTDI (09-10-2018), MetroMPG (09-05-2018), niky (09-06-2018)
