Old 09-05-2018, 10:54 PM   #2 (permalink)
cRiPpLe_rOoStEr
You mean to reinforce the stock floor pan in a way that might resemble the work done to convertible cars in order to compensate the lack of the structural rigidity provided by the stock bodyshell? Anyway, I'd most likely try to make a custom frame (probably a tube frame) and then fit the subframe with the drivetrain into it.
