Now that the alternator disable circuit is in and working like it should, I need to install my 110V charger. I happen to have the one I used on my Metro. Its a Soneil 5A smart charger. You don't have to press any buttons on it to get things started, just plug it in and it charges. Once it is done charging it float / maintain charges the battery. So, when I get home at night, I plug in and when I leave the next morning I unplug and go.
To make things more convenient, I picked up one of these flange mounted outlets.
I drilled a hole in the front bumper cover hear the driver's side light to mount it.
And the outlet gets fished through.
A few more screws to hold the flange in place, and its installed.
Now, to install the charger. I want the charger inside the cabin to keep it out of the elements. This means passing the power cord, and the charging wires through the firewall. So, I found the main rubber grommet that the wire harness passes through, and I poked a hole in it. Then, I took a metal rod and shoved it through, taped my wires to it, and pulled them back through.
That is where the progress ended for the day as it started raining out. However, I did get a few shots that show how the plug looks and works. I think it blends in nicely and it really is quite convenient.
