Originally Posted by samwichse
Unicorn corral, here we come.
I have argued it on other threads if you are willing to look it up. No, these electrolysis in a jar running from your alternator are not going to do anything practically positive, but judicious use of the output gas in extending the lean limit in a lean burn engine is very doable.
But it is not as simple as the video portrays. You will need to be able to control your fuel and ignition timing. You will need to have an efficient electrolysis device that is controlled to produce your gas as needed. You will be able to only use this tune in lightly loaded regimes. Your emissions will change. On and on.
There is basis, just not a practical basis most Ecomodders can use.
This is for spark ignited gasoline powered engines.
Diesel engines are another story altogether.
