Old 09-07-2018, 01:45 AM   #10 (permalink)
cRiPpLe_rOoStEr
Originally Posted by RustyLugNut View Post
If you can produce the HHO gas and use it to recover enough wasted energy from the engine, you can come out ahead, if the energy expended is less than the energy gained from the combustion waste.
Energy can be retained or transformed, not created. And there is some energy dissipation throughout the electrolysis process. You know, for example, a voltaic arc is quite hot, which means it's converting a part of the electric energy into thermal energy that is harder to recover. So, in the end there will be some waste of energy throughout the whole process.
