Ac to dc low voltage high current
Hello.
At the moment i drive an hybrid car witch has in perfect conditions an electric range of 50km. To work and back home is 54km. So i cant do that full electric. The furthest i went was 52km without diesel or recharging.
At work i have 4 AGM 12V batteries and an 2000W ac inverter in the trunk and with that i recharge the car partially so i can get home full electric. The power inverter accepts a voltage up to 16,5Volt. And stops at 11Volt.
I have around 10kWh of lithium cells. And want to build an 4cell serie configuration.
But the current charger is only for lead batteries and wont charge higher then 14,6Volt.
I need an 16V charger so i can use the litium batterie.
I want to build or buy an charger that can charge the batterie in maximum 8 hours.
Is there an solution for me?
Thanks in advance.
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011 + 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
