Old 09-12-2018, 09:16 AM   #108 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I got a surprise thunderstorm last night and my 16amp 240v duosida charger got wet before I could run out side and pull the j1772 and drag the whole thing inside.
The amber fault light was on.
I was able to open it up and dry it off and it's working fine again.
You have to keep your EVSE brick dry, I could have probably put it up under the hood.
Normally the EVSE brick is up under the porch over hang or inside the garage but not last night.
I only have a wall mounted L2 unit, but my plan when I get a mobile evse is to use a small plastic tote to keep the brick dry.
