Each state has its own motor vehicle laws. Generally 30 mph is the upper limit for no registration. Cooling the field coils helps efficiency. If you are worried about high rpms destroying the armature use a high temp epoxy to secure the windings, have the armature dynamically balanced, and get the best ball bearings available for the shaft. A good aero body shell will reduce power demand.
