Originally Posted by elhigh
IIRC wasn't the APC in "Aliens" an airport tug? And they had to remove thousands and thousands of pounds of ballast and still was pretty damned heavy.
An A380 is 570 tons - 1,250,000 lbs
300-400 ton airplanes are quite normal
They're not going to start moving if the tug has no substance
