Originally Posted by teoman
I am not sure, a fuel pressure sensor, and the injector can be pulsed accordingly.
That way one would also have the benefit of water injection (lowering intake air temperatures).
Did you not mention 9 deg C was the lowest temp for diesel intake, lower and combustion suffered?
According to Cummins they recommend their engines draw air from inside the engine enclosure if the engine will be regularly started and operated in temperatures less than +20F.
The reasons given were to reduce start up wear and increase fuel economy.
