Old 09-15-2018, 04:20 PM   #2922 (permalink)
aerohead
Space Weather
I have you are right about global cooling.
Irradiance isn't the only thing put off by the sun.
Solar wind speed, density, charge vary hugely.
So of course the church of global warming focuses on the one part of the sun that only changes by 1%.
I like how the believers assume we have not learned anything new about the sun since 1995.
Only shortwave solar irradiance is associated with the greenhouse effect.It comes in past the greenhouse gases,strikes the Earth, is converted to long-wave infrared radiation,which cannot get past the greenhouse gases,holding the heat energy in the atmosphere,raising the temp..
Solar wind and any anything associated with it, has never been corroborated as a forcing mechanism for global warming.
Climate 'scientists' don't assume anything.Scientists are skeptics.They do use hypotheses,which can then be tested to establish whether or not there is a causal link in the area of study.If different scientists reproduce the experiment elsewhere,and come up with the same results,it begins to take on credibility as probable explanation for the observed phenomena.
If you read their work it will become immediately obvious.
Since 1995,there's no reason to look for anything other than greenhouse gases as the forcing mechanisms for global warming.
'Towards the Detection and Attribution of an Anthropogenic Effect on Climate,' by B.D.Santer et al.,PCMDI Report No.21,Lawrence Livermore National Laboratory, obsoleted the need for any other explanation for climate change.
Re.SCIENCE,Volume 268,16 June,1995,pp 1568
I don't know what the 'church of global warming' is.
'Believers' have been defined as those who subscribe to the science.Since scientists do not assume,it follows by default,that the believers don't assume anything as well.
Scientists do know very little about the sun's corona,and have recently launched the Parker Solar Probe, which will bring an instrument suite within 4-million miles of the Sun.
But again,whatever they learn there will have nothing to do with climate change.
NeilBlanchard (09-18-2018)
