It's not that biodiesel's lubrication characteristics are bad. Biodiesel's problems are as follows:
1. It clouds (turns to Jell-o) at 35 degrees F.
2. It costs way more than dino-diesel.
3.The feedstock is food or something grown on arable land with fresh water that could be used to grow food.
Now,if algal bio-diesel can be made to work well the third problem goes away.
4. The EPA hates diesels and bio-diesel cannot be used in spark-ignition engines.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
