Old 09-18-2018, 08:50 PM   #78 (permalink)
IamIan
IamIan's Avatar
Originally Posted by Natalya View Post
A couple items...
First:
I have OBDIIC&C and I have a MIMA unit but that isn't installed, but I have it and could install it. Is there a way to use either of those to limit regen braking current to the IMA? I was thinking about this:
Yes.
OBDIIC&C will allow you to see what is happening .. it's a display .. so set one of your items to view to be the HV-IMA battery amps.
It also allows you to tell the car what to think the SoC is .. high ~80% , medium ~60% , low ~40% .. doesn't matter if the SoC is actually / really high , it might not be .. it might only actually be like ~60%SoC , when you tell it to think it is ~80% .. OBDIIC&C allows you to make the car think and act like it is high ~80% (or mid ~60%, or low ~40%) .. at least for a long as it takes the car to eventually figure out (with it's sensors) the SoC is something other than what you told it to think .. then it adjusts the SoC to what it thinks .. or until you tell it to think something else again.
You can use this to disable further regen , but telling the car to think the SoC is high .. even if it isn't actually high .. the car will act like it is .. ie not do regen into a full high SoC battery.
Note .. in very cold weather the car is more willing to do small amounts of regen into a packs even if they are already at a higher SoC.
MIMA .. as in MikeD's MIMA .. yes if you already have that it has a couple different ways it can be used .. ABC-Mode set for low amounts of regen might be easiest .. you can click in and out of is any time you like.
OEM-Mode:
MIMA does nothing , lets the car act OEM.
Manual-Mode:
Anytime you use the joy stick you can manually control how much regen or assist the car tries to do.
ABC-Mode:
If you put MIMA into ABC mode ... which stands for Adjustable Back Ground Charge .. It also almost entirely removes Assist (like ~99%), no matter how far the gas pedal goes down.
You can configure ABC to use a certain amount of regen .. some people just set it to zero .. so they can use this feature to turn back ground charge and regen braking off (or way down) .. you can set it for things like 1 Amp , 2 Amps ,etc .. Mine is set for about ~5A .. It will vary a little depending on RPM, Battery voltage, etc.
You can set what ICE Load the car tries to go into regen .. I have mine set to ~60% ICE Load (as reported by OBDIIC&C) .. so (if I am in ABC mode) , anytime the ICE Load% is less than that ~60% mine activates a small ~5Amp Back Ground Charge .. but (if I am in ABC mode) , and the ICE load % is higher , MIMA automatically removes back ground charge .. That ICE load % can be adjusted up or down.
You can get the 'mag factor' (as Mike Called it) .. which is how quickly it ramps up or ramps down from the set point you program .. mine is set to ramp up and ramp down fairly slowly , but other people like fast in fast out type of configure.
PIMA-Mode:
Stands for Programable IMA .. In this mode you program a ICE Load % trigger point (like ABC) .. but one for Regen and one for Assist .. you set your Mag factor (like ABC) , but it's for both Regen and Assist.
You could set this to come in very slowly .. you can set assist or regen at higher than OEM trigger points for the start of regen or the start of assist .. for Mine I have it set so (If in PIMA) and way down (somewhere) in the 40s % ICE load it starts to ramp in Regen .. and starts to ramp in assist above 60% ICE load and mag factor set so that it ramps all way up to ~9kw by about ~80% ICE Load (as reported by the OBDIIC&C).
You can set your assist trigger point higher .. or give it a slow mag-factor to ramp up slower .. etc.
Remember, my battery is too weak for use in assisting, it loses charge too fast probably due to dead cells in a couple sticks. But I still have it so that I can get Auto-Stop and Engine-Off-Coast with my EFAS button. A difficulty I encounter with that is that if I'm coasting for a while, let's say more than 30 seconds, if I have any kind of electrical load such as headlights or radio it'll take the voltage down until about 157 or 156 volts the batt and brake lights come on. Also, I don't like that I can charge it on the way home but then when I get up in the morning it's down to 156 or so. Anyway, dumping 30 amps into it while going down a hill with the brakes on is certain to hurt those weak//dead cells even more. Since I don't need so much of the energy all at once, is there a way to lower the current, maybe max it at 15 amps or something, using either MIMA or OBDIIC&C or through some other method? I don't want to do any more damage to the battery than has to be done.
I use ABC mode in mine when I want to limit regen to a lower level .. mine's set for around ~5A .. like very near the top , or very cold , or just dont' want as much regen drag , etc .. but you could set yours to even lower amount than what I use if you like.
My easy mode idea would be to do a charge//discharge cycle to the mystery battery pack. Maybe there's life left in it?
If A > B that might be all the information / comparison you really need to know .. as long it is better .. it's better.
Hard mode idea would be to pull the individual sticks and hunt down the ones with bad cells and throw them away and then make a frankenstein pack of 20 sticks that don't show problems and then balance charge it.
Hard mode has lots of time involved, I don't know if it would be worth it to do that. But maybe it would? What do y'all think? Also, main issue with that is I've never tried to evaluate individual sticks before, so I'd need to learn to do that. And I don't have one of those stick cycling things.
I agree trying to cycle a whole pack 1st is the easiest path.
However , pulling the 3 apart to take the best of each , and weed out the worst of each .. that is solid and time proven option .. but as you wrote it is time consuming.
As for 'worth it' .. that's too subjective for me to say if it would be worth it to you.. but I can say it is doable .. and it does have the greatest potential to give you the single best pack combined out of them all.
It isn't very hard to do at least a basic Ah capacity test series .. you can go further if you like .. but Ah at the minimum.
You just need a hobby battery charger and discharger .. there are thousands of them for sale on-line .. you need one that does at least 6 cells in series (ie 6s) or one stick .. and NiMH as a chemistry .. it needs to do both charge and discharge .. and it would count Ah and such for you .. Lower power (lower amps / watt) discharge units can be used .. but given that the car might try and push the cell very hard , the higher the discharge amp rate the better the correlation will be with how would expect them to behave in the car.
You charge a stick .. then you discharge that stick .. keep track of what the final discharged Ah were .. repeat for all the sticks .. consistency is vital .. all sticks are tested the same way so all the results can be compared .. and you can compare Ah capacity .. more Ah is better .. and the closer all the sticks are to each other the better
If you want to also test self discharge rate .. then charge the sticks up .. let them sit .. measure the voltage over an extended period of time .. at least 1 month minimum , but you cold do it for longer than a month .. from a full charge , the ones who hold that voltage longer have a lower rate of self discharge .. lower is better .. and the closer all the sticks are to each other the better .. again for the comparison to other sticks to be meaningful, you need to be consistent with all of them .. so they all go the same number of days , etc.
If you want to also test for stick internal resistance .. Start with fully charged stick .. get the voltage reading with no load on it .. then under the highest discharge load you can safely hit it with .. remember the car goes up to around ~100Amps .. so anything under that that you pull on discharge will be fine .. then after like 1second .. record what the voltage change was from the no load to the with load .. again consistency is vital , so all sticks are tested the same .. those that changed voltage the smallest amount .. from full , under the same discharge load, after the same short ~1second period .. those lowest dV have the smallest internal resistance .. lower is better .. and the closer all the sticks are to each other the better.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following 3 Users Say Thank You to IamIan For This Useful Post:
Daschicken (08-20-2019), MetroMPG (09-19-2018), Natalya (09-19-2018)
