Old 09-19-2018, 01:39 PM   #24 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
There's either a recall or technical service bulletin for the 2010-2011 Prius headlight wiring harnesses, and yes, Toyota's fix is to add length to the wiring. 2012-2015 aren't affected.
2010-2015 Priuses weren't available with HID headlights, only halogen (trims 1-4) and LED (5). The HID issue was with an earlier generation, 2004-2009.
Angel, try the simplest fixes first before you go worrying about expensive modifications like suspension bushings (which, for the record, there aren't any other than OEM-spec available). Try different bulbs first, make sure it's had the headlight recall performed, and report back. It is almost certainly not your tire pressure at fault here.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
