Old 09-20-2018, 02:27 AM   #28 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Also if you wire two connectors in series you never have to completely disconnect your voltage from your system when you swap batteries. Whats your specs on your caps and planned battery setup? It seems like a lithium ion battery built with cells with enough capacity for a car would be able to discharge the 400A needed to start your car instead and be lighter.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
redpoint5 (09-20-2018)
