Old 09-01-2008, 07:54 PM   #5 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Well, your vss is different from mine (mine had a signal, ground, and power wire) so mehbe it's self-grounding, but the signal wire should pulse 12v-0v as the wheels turn. So I'd try the non-yellow one first, tap it with a DMM, and roll the car a bit with the key in run.
