Old 09-21-2018, 02:25 PM   #9 (permalink)
HypermilerAX
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Thank you for all your answers. I think I am thinking too much in a purely mechanical way like my old AX is (being a newbie with recent cars), where injected quantity is almost only dependent on accelerator position, by cable by the way.
In the 307, injectors are electronically controlled, there are sensors everywhere... As you said, something is happening somewhere in that 1500/2000 rpm range and the ECU is commanding injection with respect to the pre-programmed map and sensor information.
I will try to investigate with more tests focused on that rpm range.
Originally Posted by twj347 View Post
Was the engine running in closed loop for every test?
Don't know. Is that only for petrol engine or diesel as well ?
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
