Old 09-01-2008, 09:16 PM   #6 (permalink)
Axaday
Originally Posted by SVOboy View Post
Well, your vss is different from mine (mine had a signal, ground, and power wire) so mehbe it's self-grounding, but the signal wire should pulse 12v-0v as the wheels turn. So I'd try the non-yellow one first, tap it with a DMM, and roll the car a bit with the key in run.
Yes, that's what I need to know. Thanks! Hopefully I can work on this again tomorrow afternoon.
