Old 09-22-2018, 12:20 AM   #53 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
33 month industrial shrink wrap skin suitability update
All is good, mileage is showing mid to upper 20's on gps spot checks @65-80mph. the only places showing any signs of uv degradation is in the locations where it got too hot while shrinking it( near burn through) . Same as the V 1.0. These overheated areas would be considered assembly defects and not allowed in a final production item. I left theas in as test points. The thermal welded points have survived on the perimeter, no delamination so far. Indicating a successful solution for an engineering failure/unknown on my part. A couple of the patches applyed show signs of either not hot enough or too hot and delaminated from the skin surface, 90% of the patches remain intact with no loss of bonding. The perimeter thermal welding has a UV protection in the skin layer to the outside. As well as a layer of mylar attached to the half inch thick styrofoam insulation has kept 100% of the perimeter thermal weld out of direct sunlight. I believe these 3 things have contributed to the UV stability of the thermal weld on the perimeter of V1.2 at 3X the test period with out fail. Keeping a role of tape and a tarp at the ready, no signs of need yet,LOL.
I also tested the 6"wide shrink wrap tape. Found in Full size pick up air dam . Quick and dirty prototyping. the tape is not UV stabilized .
By 1 year it had cracked and lifted from glue/foam uv failure were exposed cron checks/cracks .
The Blue foam bord had started turning brown from direct sun exposure as small bits disappeared.
If the air foil had any effects is unknowen . The effects were too small to see out side of normal tank to tank noise on spot checks with GPS (odo broken so I am only checking out of town long runs in excess of 3 gal./100+mi.)
ID:	24863   Click image for larger version
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
aerohead (09-22-2018), BamZipPow (09-26-2018)
