Old 09-22-2018, 02:12 AM   #9 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
6" shrink wrap tape, long turm testing.
I did a failure mode test on shrink wrap tape. . The tape is not UV stabilized .
6months
minor UV checks (~1/16-3/32" long). Adhesive holding strong. If this was in freespan, such as the air dam, would it have failed? Possibly, as a double layer like I used, in the air dam, at this point the UV would start compromising the second layer underneath these cracks small and slow but starting.
On the leading edge were the tape had a 2nd layer applyed on a 90° bias there were no signs of failure
9 months
Checks grew into cracks and tairs some foam showing
By 1 year it had cracked and lifted from glue/foam uv failure were exposed fron checks/cracks . Pices of tape came loose
The Blue foam bord had started turning brown from direct sun exposure as small bits disappeared. Leaving sections intact (light blue botches)
I Would suggest keeping this tape in the experimental category. Use it to run many short turm 3-6months (depending on sun exposure and time of year) ,or back to back tests. Such as diffrent corner shapes ducting angles, seam sealer on colorplast, but nothing permanent. Could also be used in mold making for fiber glass or carbon fiber (low temperature cure below 150° f)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
aerohead (09-22-2018)
