Old 09-22-2018, 11:29 AM   #7 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by racprops View Post
Won't work...high cost of the engine, high cost of installing it, high cost of service and repairs, the only smart way would be dump current van and buy a Van with a stock diesel.
I want to both save my current Van and improve it.
I already have the 350 as described above so the only step is to fit a 400 crank. And then assemble it.
I am then left with only one remaining question: The cam, is the peanut cam too small for the 383??
Rich
You can purchase crate Military 6.2 diesels for $50 on up and they use the same transmissions as the 350
As long as you use a C code 6.2 they last a long time, have minimal maintenance and are quite simple.
Another option is to talk to the guy below
https://ecomodder.com/forum/showthre...mpg-33961.html
A 5 speed stick is usually quite helpful
The Following User Says Thank You to rmay635703 For This Useful Post:
Xist (09-22-2018)
