Got my wheel skirt brackets made tonight, I’m using 7 on each side, which I feel should be sufficient to hold the skirt but not take me 30min to remove in case of changing a tire...
5 brackets on each side were drilled to be held in to the inner fender by the factory push rivets and two on each side have pilot holes drilled for a self tapping screw
My current Ecotec project...
My last Ecotec project...
