If it were my truck, I would internally block the entire grille where the Honda logo is and then externally blocking the entire bottom section leaving the center opening and test the results from there.
Most guys here like using coroplast, but I prefer using plastic truck mudflaps available in 24X30 or 24X36 inches and found at truckstops.
GeoMetroforum.com - got mpg?
