"And you do realize the trans, a control kit, and an installation kit will run you about $7500, right? That's A LOT of gas. Heck, it'll probably buy you a decent van."
I was planing on a Junk Yard parts, get the PCM and harness with the transmission, cross member and drive shaft.
You might have a point about using a PCM out of a car or truck with a CAN Buss system.
Will have to look into that.
Rich
