Old 09-26-2018, 10:47 AM   #12 (permalink)
Piotrsko
In aircraft, the 2 coat filler is a mandated minimum, also with cross coating. The test is a 100 watt light bulb inside the structure, in a darkened hangar looking for light bled through, usually at the reinforcement tape seams. Keep adding silver dope until you cant see bleed through. 1: not practical in this case, 2: your paint is also not high enough uv blocking solids. Rutan did find that most automotive primers had enough solids after 2 coats. He also recommended white as a primary color
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (09-26-2018), BamZipPow (09-26-2018)
