Old 09-26-2018, 04:34 PM   #67 (permalink)
sidecar
Originally Posted by Gasoline Fumes View Post
The friction brakes on my mother's 2008 Prius get grabby sometimes. The transition from regenerative to friction at low speed can be somewhat abrupt. They tend to rust from not getting used much. I clean them by braking hard in neutral.
the disk brakes have tiny rotors and tend to grab when coming to a stop. Otherwise the regen system takes some getting used to in how hard you initially brake. Once you get used to it its fine. Regen does save on brakes tho. Im over 100k miles on the original pads
The Following User Says Thank You to sidecar For This Useful Post:
MetroMPG (09-26-2018)
