Old 09-26-2018, 06:37 PM   #75 (permalink)
Crazyrabbit
Peugeot Diesel Engine
The worst design blunder is the location of the water pump at the top of the cylinder head. You only need to about a quart low on coolant and the engine overheats because coolant stops circulating. Then the rubber seals at the base of the wet cylinder liners burns out and Voila! the engine must be rebuilt.
