Old 09-26-2018, 05:58 PM   #2 (permalink)
oil pan 4
As long as you don't over heat the motor you could hit it with 90 volts, but only for a very short time.
Also that motor could be shunt wound and be roughly limited to around 2,600rpm.
The mower motors I have seen are almost always permanent stator magnet with wound armature.
