Originally Posted by deluxx
How far/fast can you go on battery only? Does it drain the battery 100%? Does it recharge with gas or only over 110V? Does the HVAC run on the battery pack? What about eco-driving? How do you do it in a Prius?
At least 25 miles.
It recharges but, not if you have a lead foot.
I can used 110v, but it is an overnight process. I plug it into 240w, and it takes about 4 hours.
I can run the a/c on battery or eco or if the battery is exhausted (as it was did driving cross country, and only concerned about making good time.
Eco mode kicks in when you DON'T push the EV button.
