Old 09-27-2018, 11:35 AM   #101 (permalink)
Angel And The Wolf
No to argue, but I always understood higher compression lead to higher engine efficiencies,
Higher compression DOES lead to higher efficiency, (note diesel efficiencies) but will it gain the percentage of MPG that offsets the percentage of higher fuel costs?
$2.59 regular, $2.84 Mid Grade, = 9.65% increase in price.
$2.59 regular, $3.04 Premium, = 17.37% increase in price
On a fifty MPG car, you would need 54.81 MPG, and 58.68 MPG respectively to justify the higher cost fuel.
and a slew of drivaeability problems with preignition, lope, and power induced throttle mania.
This is why you must step up to a higher octane rated fuel.
Valve clearance can be increased by recessing the seats and using shorter valve lift on shorter stems or a non interference cam
Yes, or leave the head and block alone, and weld something into the head beside the valve heads - think stove bolt heads - and mill those down to clear the piston crown. I don't know how much one would want to mess with valve work. A lot of math would have to go into this, so------Engine Shop.
