Old 09-27-2018, 02:42 PM   #9 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Originally Posted by mpg_numbers_guy View Post
Exactly what he said.
Have you contacted the seller and asked him why the car will require towing? in case he knows the issue being something other than the battery.
If the hybrid battery is well and truly dead, then the car won't charge the 12v battery and it's probably also been killed. You won't make it far down the road in this case, even if you bring a new one.
Probably the seller doesn't know the trick about disconnecting the plugs from the BCM that will re-enable 12v charging between 1100-4500 rpms.
