Old 09-27-2018, 04:06 PM   #109 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
All of the car's computers need to reboot, and then you need to clear the CEL. It wouldn't be a simple switch, but rather a process that takes several minutes and is multi-step. Anyhow, once the battery is that bad, the regen is necessary to have the energy for auto-stop. We're talking the final weeks of a battery's life before it does nothing, not months or years.
But didn't you used to have a calpod switch that controlled the IMA being on and off? Or maybe that was Natalya.
Yeah, if you lean out by 33% (14:1 to 21:1), you also lose 33% of your power. You're burning 33% less fuel, after all. It's not free fuel saved. It's only useful if you are only running part throttle in a given gear, leaning out let's you run a wider throttle opening and save a small amount by making less vacuum. It might also affect BSFC, but measuring that would be very difficult.
Lean burn would be nearly pointless on a Prius, for instance, because it has effectively infinite gearing. You just slow the engine down more, or toggle it on and off.
There are a few other subtleties where it's useful, like allowing an engine to actually run at a higher rpm at WOT and make the same power - sometimes this is useful, but it's not really low hanging fruit.
Ah, makes sense about less power.
About the Prius comparison though, are you saying that the Insight's ECU controls how lean it runs based on engine load?
Yep, he had no lean burn for a long time.
Not going to run 120 PSI in my tires for that though...60 PSI is good enough.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
