Old 09-28-2018, 07:06 PM   #103 (permalink)
freebeard
Whatevah. It's not a contest. I don't try to leak personal info to the unblinking eye of Internet, but I was born into a world without atomic bombs.
cooling: https://en.wikipedia.org/wiki/Meredith_effect
Pulling that air out of the engine compartment requires air flow. Your side skirts are Okay except for adding frontal area in cross-winds. You could double them up and trap air turbulence off the wheels.
Best practice with an air dam seems to be to have a central notch to put a high-speed jet down the centerline of the underbody, with a belly pan. And all that influences the diffuser design.
Wrap clear plastic in one piece from the inside of the headlights to the front edge of the front wheel well (you can incorporate air curtains) and the inner half of the curves forms a bellmouth to the radiator opening (important).
And some changes to the back.
An annular ring would create a box cavity without adding length. In the length of a trailer hitch shelf you can gain ~5% gas mileage.
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
