Old 09-02-2008, 10:42 AM   #1 (permalink)
95badbird
F150 - '97 Ford F150 Lariat
Taurus - '02 Ford Taurus SE
the 73 - '73 Ford Thunderbird
the race car - '95 Ford Thunderbird LX
The Brick - '98 Buick LeSabre Limited
My 95 Thunderbird.
No, it is not an eco car per say....but it is one of my other cars.
Some on here were asking to see some pics of it and another car I have...so, here it is.
Well, it is a 1995 Thunderbird.
It used to be my daily driver, it had a 4.6L with a 75 dry shot of nitrous.
Back then at its current weight of 3,940 lbs, it ran a best of 14.15 @96 mph, while cutting 1.99 60's on street tires.
Here are a couple pics of before....
Well, after running nitrous to long untuned, it got the best of my engine.
So, out came the 4.6 and in went a 351W and a C6 tranny.
Install was pretty fun. Since no one makes aftermarket stuff for birds, I had to custom make a few things to get stuff to fit right.
First off, to get the engine to fit, I had to cut the rear of the k-member to get the 7 quart moroso pan to fit.
Next, to get any kind of header to fit, I had to make my own steering shaft...
Had to bend my longtubes a bit to make em fit around the C6 tranny...
Still use the OEM in-tank fuel pump for now....but added a low pressure return style FPR...
throttle cable and bracket...
water pump and pulley setup..
New aluminum radiator and 2- 14 inch electric fans...
