Old 10-02-2018, 03:43 PM   #116 (permalink)
Shawn D.
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Thumbs down A Useless Test
Originally Posted by Phileaux4 View Post
He ran the engine at hwy rpm in park and measured fuel usage. The difference between that and actual mpg is friction and aero drag.
That sort of test is useless. You can't extrapolate from a no-load situation to a loaded situation by simply adding friction and drag. Throttle position, manifold vacuum (or pressure), ignition and fuel mapping, combustion temperature, and pumping losses will all be significantly different.
