Old 10-02-2018, 06:25 PM   #117 (permalink)
Phileaux4
Com Car - '06 Honda Civic EX sedan
Familycar - '10 Ford Edge SEL
Originally Posted by Shawn D. View Post
That sort of test is useless. You can't extrapolate from a no-load situation to a loaded situation by simply adding friction and drag. Throttle position, manifold vacuum (or pressure), ignition and fuel mapping, combustion temperature, and pumping losses will all be significantly different.
(My wrighting is't as clear as my thinking)
Yes with all of the accessories running in the car. If he knows the van will run 1,800rpm test it there. From the testing he'll know "the best possible is Xmpg".
