Old 10-03-2018, 05:55 PM   #9 (permalink)
IamIan
IamIan's Avatar
Use solar panel and teg
solar already done
I've been considering both TEG sides .. My ideal (might not end up being doable) would be to combine both (radiator and exhaust) TEG with a Meredith Thrust style air flow over the 'cold' air .. as the 'cold' side air absorbs heat via the TEG transfer , that cold air will heat , and expand .. and if designed right produce minuscule additional amount of thrust at the same time from the same heating of that 'cold' air
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
